logo
In order to simulate and interact with a robot in Parametric Robot Control, you need to provide the robot type and the robot driver. Both refer to classes in the PRC.Library.dll, i.e. KUKA.KUKA_KR1000 constructs a KR1000 robot via PRC.Library.Robots.KUKA.KUKA_KR1000(). The driver sets the appropriate kinematic solvers to perform the simulation. A driver may generate robot code or provide a real-time interface.
Drivers
KUKA.KSS_KRL_Driver Preview: Driver for simulating robots running KSS (KRC1-5). Outputs code in KRL format.
KUKA.KSS_MXA_Driver Experimental: Driver for connecting with KSS robots via mxAutomation. mxAutomation must be installed in a version that fits the mxAutomation.dll. Experimental, expect some issues.
UR.UR_Driver Experimental: Experimental driver with support for Universal Robots UR10e and UR20 on both Polyscope 5 and Polyscope X
ABB.ABB_RAPID_Driver Experimental: Experimental driver with support for ABB robots using RAPID.
IGUS.IGUS_Driver Proof of Concept: Highly experimental driver with support for the IGUS ReBel robot.
NEURA.NEURA_SIM_Driver Proof of Concept: Highly experimental driver with support for the NEURA MAiRA 7 robot. Generates Python code that requires the NeuraPy library to execute.
Generic.Generic_Driver Placeholder: To be used for accessing IO values and data from other robots, e.g. for an IoT device.
Robots
The following robots are currently integrated. They expand the robot library currently available in KUKA|prc.
KUKA.KUKA_KR1000 KUKA.KUKA_KR10R1420 KUKA.KUKA_KR10R14402 KUKA.KUKA_KR120KR150R31002 KUKA.KUKA_KR120KR210R27002 KUKA.KUKA_KR120R1800 KUKA.KUKA_KR120R3900K KUKA.KUKA_KR120R3900K2 KUKA.KUKA_KR125200 KUKA.KUKA_KR12KR20R1810 KUKA.KUKA_KR150240L110180 KUKA.KUKA_KR180KR240R29002 KUKA.KUKA_KR200comp KUKA.KUKA_KR20R3100 KUKA.KUKA_KR210KR240R2700 KUKA.KUKA_KR210R31002 KUKA.KUKA_KR210R3300K KUKA.KUKA_KR22R1610 KUKA.KUKA_KR250KR300R27002 KUKA.KUKA_KR3060 KUKA.KUKA_KR3070R2100 KUKA.KUKA_KR30L16 KUKA.KUKA_KR3605002 KUKA.KUKA_KR3R540 KUKA.KUKA_KR480R3330 KUKA.KUKA_KR4R600 KUKA.KUKA_KR50R2500 KUKA.KUKA_KR50R2500CRW KUKA.KUKA_KR5arcHW KUKA.KUKA_KR600R2830 KUKA.KUKA_KR610R1100 KUKA.KUKA_KR610R11002 KUKA.KUKA_KR610R900 KUKA.KUKA_KR610R9002 KUKA.KUKA_KR61620 KUKA.KUKA_KR616Arc KUKA.KUKA_KR6R1820 KUKA.KUKA_KR6R18402 KUKA.KUKA_KR6R700 KUKA.KUKA_KR6R700 KUKA.KUKA_KR816R20102 KUKA.KUKA_KR8R1620 KUKA.KUKA_KR90KR120R2900 KUKA.KUKA_KR90KR150R3700K KUKA.KUKA_KR90KR270R2500 KUKA.KUKA_KR90KR270R2700 KUKA.KUKA_KR90KR270R3100 KUKA.KUKA_LBR3R760 KUKA.KUKA_OALego
IGUS.IGUS_ReBel
NEURA.NEURA_MAIRA_M
UR.UR_10e UR.UR_20
ABB.ABB_IRB6700_150_320
